Page 4 of 7 FirstFirst 1234567 LastLast
Results 37 to 48 of 74
Thread: White Smoke...
  1. #37
    Nov 2010
    inb4yursorryass
    Mayb you've got a blown oil spark plug/cam seal.
    Causing it to burn and blow white smoke..
  2. #38
    Apr 2012
    Melbourne, S.E Suburbs
    05 DC5S
    So many different opinions. What do
  3. #39
    Nov 2010
    inb4yursorryass
    Quote Originally Posted by eLtrix View Post
    Check ur spark plugs ad see if its dark and oily.. If it is then you need to change the spark plug oil seals x 4. This should stop the white smoke.
  4. #40
    Jan 2010
    ACT
    DC2
    a solution that will answer your question as to whether its worn and burning oil or not:
    go to a shop that has a leakdown tester and have a leakdown test done.
    then you should get your answer. you'll pretty much just get guess after guess on forums until you either do some testing or get someone else to do some testing.
    -ZAMMIN-
    - Integra-GSi 19/11/2015
  5. #41
    Dec 2011
    Launceston, Tas
    '77 Civic
    Exactly. Until you actually take it somewhere and test it, it's purely speculation, and you're going to have tons of different views.
  6. #42
    '99 DC2R/'88 CRX Array
    Sep 2003
    DC2R/CRX
    Yup - diagnosing via internet is guesswork and is like checking the net for a medical diagnosis - the only real answer is going to be from the guy that slips on the rubber glove and does some probing.
    '99 DC2R, '90 BMW E30 318is, '88 CRX
  7. #43
    Apr 2012
    05 DC5S
    Cool ill snoop around in my local area if anyone does it....
    Any recommendations as to a spot i should go to? Im in S.E Burbs
    Thanks for all the help so far guys!
  8. #44
    Apr 2012
    05 DC5S
    So i made some phone calls in my local area and sadly not one could do a compression test....
    But i've had some input on several occassions that it most likely is the valve stem seal, due to the fact that "it only smokes on start and doesnt smoke when the engine has warmed up"
  9. #45
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    Pressure test. Get one done at a radiator joint. They can also do a litmus test on your coolant to see if it has carbon emissions in it which aren't always visible to the eye.
    Compression test should be manageable at any shop lol.
  10. #46
    Apr 2012
    05 DC5S
    Quote Originally Posted by dougie_504 View Post
    Youd like to think that.. but the asians around here are hopeless... damn springvale, i asked if they could do it and they didnt have a clue LOL. Not sure where else to look, pretty hopeless with this shit
  11. #47
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    Drive to Nunawading. Straight down Springvale road. Find a place called Mideast Radiators near Maroondah highway.
    If you want I'll meet up with you and take you.
  12. #48
    Jan 2010
    ACT
    DC2
    make sure you get a leakdown test, a compression test is no replacement for a leakdown. compression test will give you an idea as to whether its sealing reasonably ok, but the leakdown will actually tell you how much is getting out and where.
    normally the symptoms for bad valve seals will be smoke at high RPM and under load, does not completely go away when warmed up. valve guides is another culprit in B series but don't jump to conclusions until you can prove what's causing it.
    -ZAMMIN-
