Hey guys, Ive got a knocking sound comming from the rear of my EF CRX, ive checked all the bolts and there all tight so i dont know what the problem is. Any suggestions will be appreciated.
Bumppp
Is it lowered? Got aftermarket exhaust? Might be exhaust piping hitting swaybar
Yeah it's lowered on coilovers and does have a exhaust, how can I check if it's hitting?
See where the exhaust piping goes over the swaybar and theres a decent gap,check yours and see if its too close or signs of rubbing
Would this cause a knocking sound though? It's pretty loud
is there anyway you could get a video of the sound to show us ??
DA9 B18c2 http://www.facebook.com/RisingSunBaseJumping Base Jumping & Wingsuit Flying is my LIFE
I can't get a video but I can describe it, it doesn't start knocking at first then maybe after 30 seconds of driving it starts and when I brake the knocking isn't as loud and when I turn I think it gets a touch louder
If your sway bar gap is like that, you should hear the knock more when you turn right or when you straighten from turning left aggressively.
-------------------------------------- Stocky CL9 - 1:17.2
Okay so if this is the case how do I fix it
You dont know if its the case yet,you need to visually inspect to see if theres been contact or not It may be something else as far as we know,just a guess at this stage
I'll check it out tomorrow but if it's the exhaust rubbing how is it fixed
