Bendix can help you diagnose and solve your brake problems.
To help you fix brake problems you may be experiencing, we have prepared some helpful tech tips to ensure you achieve optimum braking performance and safety.
As there are a number of issues that arise with your cars breaking system, its always good to keep a look out for the possible symptoms below.
Brake Wear
What is brake wear?
Abnormal brake wear is when the brake pad or lining wear at an abnormal and accelerated pace. Brake pads and linings will wear at a normal predictable rate if fitted properly but under certain conditions this wear can be extreme.
How does brake wear happen?
Abnormal brake wear occurs when the wrong type of pad or lining is fitted or the rotor surface is rough, it may also occur when the caliper pistons or pins seize up.
Is there any way of preventing this from occurring?
Choice of pads and linings is crucial to the stopping performance of a vehicle, choosing the right pad is as important for its durability as it is to safety. Regular maintenance of your vehicles braking system is essential for its integrity and longevity.
Probable Cause & Corrective Action
- Wrong type of pad or lining material for operating conditions. Replace with correct pad or lining material
- Caliper pistons and/or pins seized. Fit pins and seal kits.
- Extremely rough rotor surface. Regrind rotors.
For more useful Brake Problem Tech Tips from Bendix, visit our tech page by clicking here
Bendix offers a wide range of pads and drum shoes, from street to track applications. Click here for information on our latest range of Street Road Track high performance pads!
