Results 1 to 10 of 10
    Aug 2012
    Adelaide, Australia
    DA9 Integra
    OIL LEAK!, Not sure if its the rocket cover gasket or not! photo inside
    Hey guys,
    Just abit unsure what the cause of my oil leak on my B18A1 motor exactly is.
    The leak appears to be caking underneath the the area high lightened in the photo below and oil seems to be leaking underneath the black cap in the red box in this photo.
    This photo is not my motor just a reference...
    Any ideas??
    Cheers
    Oct 2004
    www.alibaba.com
    porsche boxster
    Cam seal,common leak spot for b series
    Get a new one
    Aug 2012
    Adelaide, Australia
    DA9 Integra
    Cheers EKVTIR-T
    Will the rocket cover need to come off, and if so will I need to replace that too?
    Oct 2004
    www.alibaba.com
    porsche boxster
    Yeah,need to remove rocket cover.
    The cover uses a rubber seal but if its not leaking then no need to replace it
    here is a DIY showing the cam seal replacement and cover gasket http://www.team-integra.net/forum/bl...placement.html
    also,when tightening the rocket cover bolts DO not over tighten as many people snap them off with too much torque
    Quote Originally Posted by EKVTIR-T View Post
    Just to add - do NOT tighten any small nuts / bolts like the ones found in the upper head when the engine is HOT - this greatly weakens the bolts and they will snap easily.
    Tighten these when the engine is cool
    Oct 2006
    Melb
    P1.5 460F/350R
    good info hear guise, by the way..
    S P A M | W O R K S
    Sep 2008
    Western Sydney, Nsw
    EF8
    Trollolol
  8. #8
    Jan 2010
    ACT
    DC2
    I wasn't aware NASA made covers for their rockets?
    -ZAMMIN-
    "I know who you are, and I know if I make a formal complaint Mr. Benjamin will have to roll over and give me all your details"
    - Integra-GSi 19/11/2015
  9. #9
    How do you replace the cam seals on the camgear side? Looks like the gears and timing belt has to come off?
  10. #10
    Apr 2012
    WST SYD
    GOLDWING FTW
    u will have to remove the cam gears
    dodgy engine james middle_name_james naughty_james noise thak_thak vibration
    View Tag Cloud
