I hope someone can help me, this is very fustrating!
I have an EG 92 with a B18C running a EMS Stinnger ECU piggy backed off the standard ECU
Majority is perfectly wired and the car starts / runs etc
The main things here you need to know before i proceed.
The Loom is from a EK and is AUTO! It was hard to find a manual OBD2 Loom (people say you cannot used these haha!
The issue!!!!!!!!!
RPM taco is not working.. sounds typical and simple right ... lets see if you can solve this and help me grow my hair back on my head.
1. Dizzy has been removed and has now been replaced by a CDI and running Coils.
2. The Plug has a blue wire on the other side its connected to a blue wire this is wire i need...?
3. This blue wire runs into another blue wire that is bridged of it that has a black cap on it i think is for testing? then the two blue wires run into the car to a plug near the fuse box under drivers side dash.
3. This plug has nothing on the other side? should this go to the cluster? there is already a blue wire there...
4. At the standard ecu, research shows that there are 2 wires and these are red. one is to be cut and the other used (connected to the AUX on the EMS) as the standard ecu is not the brains anymore.
Im losing the plot here! HELP! me and help many more like me.
Thanks.
