Page 1 of 3 123 LastLast
Results 1 to 12 of 26
    Mar 2012
    Prelude Vtir
    Question Vibrating after cam belt replacement.
    Hi guys
    Just got my water pump replaced so did the cam belt at the same time. Problem is the engine is now vibrating quite a lot. I Can notice it at idle and gets more intense as RPM increases. It is bad enough that when im driving at 4000 RPM and higher the rear view mirror is blending 2 cars into one. Ha
    Is this normal with a new belt and will it reduce as the belt slackens a bit???
    Or do I take it back to the mechanic and say 'whats going on here'
    Cheers,
    Russ
    Banned Array
    Apr 2011
    Perth
    B16EG-GD3-DC2
    call him ask if its normal. rather then driving back. im thinking its not timed properly or something like that.
    Banned Array
    Apr 2011
    Perth
    B16EG-GD3-DC2
    i wouldnt drive it incase your causing damage
    Oct 2010
    Laser,B16EF,DC2
    how the fuk did your mechanic think it was ok to return the car like that??
    Oct 2010
    Laser,B16EF,DC2
    was it doing that when you picked it up?? looks like timming is out
    Banned Array
    Apr 2011
    Perth
    B16EG-GD3-DC2
    i wonder if he will pay for the new valves....
    Dec 2008
    835 Beaufort St
    hondie 2000
    tell ur mechanic to getfkd
    sounds like it might be out a tooth or somethinig
    no way should a belt slacken
    or maybe he forgot the harmonic balancer
    hehe.
    PHC
    Oct 2010
    Laser,B16EF,DC2
    now how did he forget the harmonic ballancer?
    Dec 2008
    835 Beaufort St
    hondie 2000
    Quote Originally Posted by SLOBRO View Post
    By being an careless i suppose.
    Some poeple remove the harmonic balancers intentionally and don't complain about shakes as bad as the OP described..
    maybe the harmonic balancer's on backward (i.e. doubled the vibrations instead of cancelled them out)
    hehe.
    PHC
    Oct 2010
    Laser,B16EF,DC2
    wait r u a mchanic? u can't possibly leave out the harmonic ballancer or let alone put it on backwards
    not possible to leave off the harmonic balancer or put it on backwards....
    Consider a engine mount might be too tight / broken / loose giving you this vibration. Maybe the rear engine mount is stuffed.
    Is this vibration in gear while driving ? Or can you replicate it in neutral as the car sits stationary ?
    Jul 2009
    Mango Of The Hills
    EG8
    backwards Harmonic balancer doubling vibrations. Hahahaha duuuude so so so many fails right there. Doubt you know what a crank pulley is??.
    Anyways OP. Id say it is a loose engine mount or two, check passenger side torque mount and rear mount. Id say passenger side, how I know?? Left mine loose and got similar thing.
    Why don't you tell your daddy to comb his damn hair, look like some spiders is having a meetin' on his head.
