I've just picked up a set of wheels with tyres, and the overall diameter is around an inch more. Will this cause any problems, and what effect will it have on the accuracy of my speedo? Cheers.
http://www.miata.net/garage/tirecalc.html
http://www.carbibles.com/tyre_size_calculators.html se agua amigo
S P A M | W O R K S With our special rotational tires, it will allow you to drive very fast. - JK Tyre
Awesome, thanks. I'm also trying to learn the stock diameter. Did the DC4 come with 195/60 R14 as standard?
check your door jamb
Personally id just stay within 2% of the stock tire. Increasing height will affect acceleration. When ever you mess with wheels or tires you need these 2 links. http://www.1010tires.com/tiresizecalculator.asp http://www.1010tires.com/WheelOffsetCalculator.asp
