Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: B18c/b18c7 help
    Aug 2008
    Sydney
    EK
    B18c/b18c7 help
    Hey guys before you tell me to search, I've searched already and done my research . Now I just wanna clear things up and any feed back would be awesome
    1) Im aware that b18c7 or b18c would fit straight into a EK1 with along side me getting EK4 wiring harness, b18c/c7 ECU, B series shafts and B series linkage. Is this correct?
    2) Will my AC Pipe fit on to the B series AC compresser ?
    3) Will my Power steering fit hose fit straight on?
    4) And last question will i need to run any other new wires from ecu to engine to get it started?
    5) fuel pump ? should I get a b series one?
    Thanks guys , dont troll please be nice =)
    B-serious m8
    imo, b18c7 wont fit straight in without Ek b mount.
    everything will fit straight in, as long as you use B parts from Ek VTIR
    h2b all motor- RIP
    FN2 -RIP
    GTI- RIP
    A 45 AMG -RIP
    C63 C205
    Feb 2011
    gympie QLD
    DA9,DA3,EG,DA9
    ^^ agreed. get all b series EK parts eg. mounts, supports, brackets etc. should make the job much easier..
    Jan 2012
    Sydney
    Ek hatch b18c7
    Use a crv Ac bracket and put the d series compressor on your b18.
    Jan 2012
    Sydney
    Ek hatch b18c7
    Also need an integra ps pump.lines fit fine.
    Ecu will need an immobilizer removal. Google it. Whole DIY guide.
    Ek4 engine mounts. Except below
    99 si civic. Rear bracket
    99 si post mount passengers side
    Use same tranny mount
    Jan 2012
    Sydney
    Ek hatch b18c7
    Pm me if u get stuck!
    Sep 2008
    Western Sydney, Nsw
    EF8
    you mirrin the b series
  8. #8
    yes
    no
    yes
    no
    yes
  9. #9
    1) Im aware that b18c7 or b18c would fit straight into a EK1 with along side me getting EK4 wiring harness, b18c/c7 ECU, B series shafts and B series linkage. Is this correct? YES
    2) Will my AC Pipe fit on to the B series AC compresser ? No but you can get CRV b20 AC Bracket and you can use your d series compressor or get EK4 Ac hose to use b series compressor
    3) Will my Power steering fit hose fit straight on? Yes, there is 2 types of b series PS pump, 1 for late model and early model
    4) And last question will i need to run any other new wires from ecu to engine to get it started? NO
    5) fuel pump ? should I get a b series one? Use your stock pump
  10. #10
    Jan 2012
    Sydney
    Ek hatch b18c7
    + 1 vtec1987
  11. #11
    Aug 2008
    Sydney
    EK
    Quote Originally Posted by VTec1987 View Post
    ALSO need B series mounts ? and T bracket from which car?
    B-serious m8
  12. #12
    Jan 2012
    Sydney
    Ek hatch b18c7
    So ek4 mounts.
    Rear bracket from 00si civic
    Post mount passengers side 00si civic
