Results 1 to 12 of 15
    Sep 2012
    Honda Civic 96
    Honda Civic 96 EK1 Leaking Oil from some Engine Part
    Hi All,
    I am new to this Forum & came for help after taking my Honda Civic to a few mechanics & spending money without any output.
    My Engine Oil is leaking from the red colour indicated part shown in the attached image.
    I do not know the name of that part but Oil is leaking beneath that part.
    It started when I got my Timing Belt replaced but timing belt is on the other side of this leaking.
    Please kindly tell me what should I do as I have already spent about 400$ to different Mechanics claiming to replace some seal.
    Any help would be greatly appreciated.
    Thanks & Regards
Name:	Leak Cause12.jpg
    Aug 2009
    Blacktown
    eg civic
    if its that change the vtec solenoid gasket and while you're at it change the dizzy o ring both should cost 15bucks together max
    Sep 2012
    Honda Civic 96
    Thanks a lot 2MPRS.
    As I have no experience of doing any car mechanical work, please guide me if it is easy to do.
    If not, please let me know of some good mechanic who can take care of that in fair amount of money.
    Best Regards,
    Aug 2009
    Blacktown
    eg civic
    this is for the vtec gasket http://www.d-series.org/forums/diy-f...eplacment.html
    this is for the dizzy o ring http://hondaswap.com/general-tech-ma...-o-ring-81866/
    quiet easy to do imo
    Aug 2009
    Blacktown
    eg civic
    heres on for the vtec gasket only thing i could find http://www.clubcivic.com/board/showthread.php?t=215914
    Oct 2004
    www.alibaba.com
    porsche boxster
    Heres what the seal looks like
    you can replace it yourself easily,just google a DIY
    Aug 2011
    South East Melbourne
    Civic EJ8
    hmmm if does ek1 have vtec solenoids too? Are you sure its from that area and not coming from your transmission area?
    Sep 2012
    Honda Civic 96
    Hi Mattsrea,
    How do I confirm that if the oil is coming from the Transmission area ?
    Please advise. Thanks.
    Dec 2011
    HRV k24a
    get a cloth and brake cleen and wipe up all the dripping excess oil from the area, (everything), then run the engine or a little drive and then you should be able to pinpoint the exact spot its coming out from
    1975 EB1 Civc 2 speed hondamatic
    WTB; chrome roof rack to suite^^
    Sep 2012
    Honda Civic 96
    I tried that a few times & unable to find out other than from beneath the area under Vtec Solenoid Gasket.
    Is there any good mechanic or person near my area (Merrylands, 2160, NSW), who would be able to fix & I am willing to pay.
    I just need an expert as I already went to a few mechanics & no one has been able to fix the issues.
    It is very hard to find a good & honest mechanic.
    Please help. I will be highly obliged.
    Many THANKS......
    Aug 2011
    Civic EJ8
    Um well, you can try "the honda doctor". I'm not sure where they are but im pretty sure its close to merry lands. They should be 100% be able to fix it for you if you really don't know whats wrong with it.
    Aug 2009
    Blacktown
    eg civic
    i looked at the car today its leaking from all around the head and bogs down threw the rev range and has no power whats so ever he needs to either replace that motor or take the head off to see whats wrong with it imo
