Hi guys,
well my little project is moving along nicely. i've got my ITBs made up, a vac box some lumpy cams. I've also got a obd0 - > obd1 conversion harness and a D16A8 OBD1 ECU (unopened) and a dizzy.
Now im finally getting my ECU sorted i found a Hondata s200 and a P29 ECU. I also have a Apexi AFC-NEO (i was told this is a good to fine tune it, and i got it for peanuts brand new so if i use it or dont use it makes no difference)
I also plan on getting a wideband and gauge so i can try to do some tunes on my own down the track.
My questions are as follows:
Will a S200 be enough to run ITBS?
Using the AFC Neo is this going to make things harder or easier?
I've heard mixed reports, some people say that it will be good to fine tune the fuel and others have told me its not going to be doing anything useful and it might hamper the s200 - whats the right answer?
Should i upgrade my TPS?
Im using the TPS that is on my ITBS (ITBS are a custom made unit using the CBR600 TPS) is there any need to upgrade this or should i just swap this with the standard one?
Should i upgrade my MAP?
Again i would just be using standard is there any benefit in upgrading for ease of tuning?
Any help for the above would be welcomed
Cheers
EDIT:
My ITBS:
