Results 1 to 7 of 7
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    b18c block guard question.
    Hi,
    has anybody use this item before?
    http://realstreetperformance.com/sto...b18c5-469.html
    any feedback?
    any modifications to fit this?
    any other brands you recommend? eg. golden eagle, erl etc?
    thankyou
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    You'd be better of sleeving your block. I have read reviews on block guards, and people say they are not needed and are just a waste of money:
    http://honda-tech.com/showthread.php?t=2674171
    EG
    Mar 2007
    D15B7 YOOOOOO!
    hmm, i have read on about sleeving, machine shop suggested decking it which will support the walls, haven't been through or seen that process have you?
    Quote Originally Posted by na-118 View Post
    nope, sorry. Goodluck with your build!
    EG
    Apr 2012
    WST SYD
    GOLDWING FTW
    as far as i understand the expansion rate when heated is diferent to the block and in some cases can put stress on the liners ive seen these fitted tigg welded the the block decked pros and cons im not sure ensure the water jackets are drilled in the right position and that they match up on the head gasket
    Good Luck
    View Tag Cloud
    Jan 2010
    AccordCB7 Turbo
    Do not use this.
    That Hondatech link is a good read too!
    If you have an open-deck Block and steel sleeves you should be able to give that Motor some serious power before you'll run into problems.
    For example my F22A (open deck, 1mm oversize bore) can push 400WHP before my sleeves start to 'move' and break the seal on my head gasket.
    I have the option of Darton/GE Sleeves but for the cost i'd happier to have a reliable 300WHP instead.
    Jan 2011
    QLD
    EP3
    used it on a boosted b16 (525hp)
    Works fine had no issues
    Just follow the installation instructions
