Page 2 of 30 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 359
  1. #13
    Jun 2012
    Perth
    CD5 & GE6
    Nothing that i can see man
    I'm thinking an internal leak
    Before the cruise i'll replace my bleed my brakes and check the whole system thoroughly
    Hopefully next year
    i'll get my braided lines, pads and master cylinder done
    You've gone through more accords than I changed underwear this month! - Sugz
    www.OzAccord.net/forum
  2. #14
    Jun 2012
    Perth
    CD5 & GE6
    Few updates in one post
    oem genuine type R badge - shall NOT go on Accord LOL
    oem bonnet protector
    Because i couldn't get 'little racecar driver on board'
    I got this instead to pay homage to my azn heritage for my newborn lol
    Turns out the last owner of my cd5 neglected to put back the rubber boot over the headlight housing connecter...
    The H4 bulb was held in by its connector and sticky tape...
    So i grab the rubber boot from my spare headlight and i pop everything back together
    Come back and the connector has literally melted /sigh
    S'okay shall source parts from cb7
    Fixed the headlight problem
    Turned out the grounding wire's insulator was worn away and shorted out - thus melting the plastic connector
    Went to the cb7 and took its connector
    Soldered and heat shrinked the ****er (had to remove air box assembly to make room) THANKS JJ/GENE A.K.A GU537
    All good now
    And the oem bonnet protector's holes didn't match up with my bonnet ( i assume it was suppose to have special clips to attatch it to the bonnet)
    It would literally fall of the car when you pop the hood lol
    Ended up drilling 4 holes in the bonnet and fitted cable ties - bazinga!!!! Doesn't fall off THANKS AGAIN JJ/JENE A.K.A GU537
    DIY-ed front lip respray
    Cheers for reading
    Next up...
    Side skirts and rear lip respray
    Mugen badge & SiR
    Blackhoused headlights
    Amber signal lights and corner lights
  3. #15
    Oct 2006
    Melb
    P1.5 460F/350R
    Accord Type R.
    nice man. Type R is the best
    S P A M | W O R K S
  4. #16
    Dec 2008
    835 Beaufort St
    hondie 2000
    can i pls have the type R badge? It will go well with my genuine type R stickers.
    S P A M | W O R K S
    hehe.
    PHC
  5. #17
    Jun 2012
    Perth
    CD5 & GE6
    +25kw from the Type R badges
    I might put it on my vacuum - extra suction power
  6. #18
    Sep 2007
    Australia
    your mum
    put it on curtis ****, he needs some back up lol
    Quote Originally Posted by Jasemas View Post
    connorling, your profile and evidenced by your post tells me alot about what type of feral you are..... all class 'hay'!!!! ps. not your m8....
  7. #19
    Jun 2012
    Perth
    CD5 & GE6
    Crappy update
    Driver's seatbelt has started fraying
    I've put it down to my shoulder pads - velcro is ripping em apart
    So anyways
    I take out the seatbelt assembly fromthe cb7 and take out the cd5's assembly to
    Try putting in cb7's seatbelt... Doesn't fit /rage
    So i'm on the look out for a new seatbelt
    On the otherhand
    Pod filter in
    Another shout out to JJ, Gene aka GUE57 for helping to install XD
  8. #20
    http://www.perthwreckers.com/wrecker...Recyclers.html <- lots of older stuff
    http://www.perthwreckers.com/wrecker...+Wreckers.html <- dude was pretty nice, served me 5 minutes before closing
  9. #21
    Jasemas ... if you need some bits and peices ... $450 aint bad :-P
    http://www.gumtree.com.au/s-ad/lesmu...ord/1012978447
  10. #22
    Jun 2012
    Perth
    CD5 & GE6
    Quote Originally Posted by lolmclol View Post
    Cheers man
    I got my seatbelt from a guy in rockingham
    Mrs. says i have too many wrecks (only 1 atm) and im about to move
  11. #23
    Banned Array
    Apr 2011
    Perth
    B16EG-GD3-DC2
    oi can i buy dc2 wreck and strip the brakes and tie rods leave wreck at your appartments
  12. #24
    Jun 2012
    Perth
    CD5 & GE6
    NOT ****ING HAPPY
    PERTH SH1T KENT DRIVERS
