Page 2 of 2 FirstFirst 12
Results 13 to 16 of 16
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Quote Originally Posted by DLO01 View Post
    I believe this setup with the D is different to say a B. As in the photo the IACV bolted to the underneath of the TB so you can't exactly isolate the TB from water entering it (thats how I see it). On a B you can totally isolate/bypass the TB because there is a hose from the TB to the IACV.
    Removing the heated water lines from the TB is a good thing for performance. Who cares about proving it, to be honest, yes, its negligible and you probably would not see any gain at all. But it certainly a step in the right direction rather than a backward one. All little negligible gains add up to a larger one.
    D and B are the same round abouts from memory
    I did the same setup for my Turbo D16Y1 then my turbo B16A I believe
    But yeah remove heat whenever possible IMO
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    Nov 2009
    Civic EJ8
    ahhh cheers guys some good information.... ill def need to look into routing it from the block, once i get the car up 2morrw to bolt up most of the gear up
    I <3 BOOST! D16+T SOHC
    Ozhonda Supporter Array
    Jul 2004
    MV Agusta F4
    Quote Originally Posted by Lukezen27 View Post
    Nar, my B18C7 is different to the pic on 1st page, not sure about other B's.
    Deano.
  4. #16
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    My b16a2 i just closed off the coolant like Luke did.
    I actually did this before i boosted it even. Had no issues.
    He is right every little bit helps. The coolant to the TB is for japanese conditions where temps get below zero to stop a frozen TB.
    Doesn't really happen in AU. ALso if you've boosted your car, lack of heat is certainly not a problem.
    Evo IX - THE FINAL EVOLUTION
