Results 1 to 5 of 5
    Nov 2011
    Sydney, NSW
    MX5 CB400S4
    ek4 Strut brace in an ek1
    Im about to install an ek4 strut brace in my ek1 and want to no if i can tap threads into the chassis opposed to using a nut and bolt to hold the sturut brace in?
    Thanks.
    EK1 Daily Drive.
    just drill out the supplied holes and place a nut and bolt thru there....a 10mm or 12mm headed piece does the job
    Nov 2011
    Sydney, NSW
    MX5 CB400S4
    Is there a reason not to tap a thread?
    EK1 Daily Drive.
    Jun 2006
    Brisbane
    K20 DC2R
    that metal that blanks over the holes r so thin the brace would probs pull the bolts right out of the thread. in an ek4 there are threads welded to the chassis
    Apr 2007
    Sydney
    91 ED9 CRX
    Drill the holes out, put a bolt through and put a nut and the biggest washer you can fit under there...will not pull through
