Check your clutch fluid and make sure the master cylinder isn't leaking.. Had a similar issue at one point as the seals on the clutch master cylinder was on its way out.. Got a brand new OEM and fixed the problem..
So get down under the pedals with a light and see if there is fluid residue.. And make sure fluid levels are okay
