Results 1 to 4 of 4
    Dec 2012
    QLD
    EG5 VTi
    d16y1 Starting Problem
    Hey fellow ozhondas I am having touble with my d16y1 motor in my EG civic. When ever I try to start it, it cranks over but the engine wont start until the check engine light turns off.
    Any help be appreciated
    Before you go ahead and change anything, scan your ECU for codes and cross check them with this list. Will give you an indication of what's shagged
    http://www.ozhonda.com/forum/showthr...ECU-for-j00-!&
    I had a similar problem in my d16y1, was the ICM in the dizzy, popped a code 15 ignition output signal
    KEEP IT VIET | KEEP IT JDM
    FaLL iN LoVe WheN YoU aRe ReAdY, NoT WhEN YoU ARe LOnEly
    Green block gangster Array
    twin GX160's
    Hi
    your ECU has failed, I can fix it for you if your interested
    Dec 2012
    QLD
    EG5 VTi
    Hey charliebrown thanks for showing me the DIY ecu write-up but I'm not to confident about touching that stuff by myself cause im quite new to honda.
    And ECU-MAN if you can fix it pm me thanks.
