Page 1 of 2 12 LastLast
Results 1 to 12 of 21
    Aug 2005
    Cali, Melbourne
    DC2R / S2000
    ITR 5 Stud Question
    Is The JDM 5 Stud a direct replacment for an AUD ITR 5 stud? (just change over of hubs)
    JDM DC2R (98 Spec) 5 stud uses larger front hubs and subsequently thicker driveshafts
    aka 36mm hubs/driveshafts
    Aug 2005
    Cali, Melbourne
    DC2R / S2000
    Quote Originally Posted by dorikin View Post
    so if i have a JDM B18CR that pre 97or98 then aus hubs will fit?
    thanks for the info guys
    Jul 2010
    Melbourne
    ek1
    So would a jdm itr 5 stud fit on ek1 driveshafts?
    oldskool Civics FTW
    Jan 2010
    Brisbane
    Integra
    Quote Originally Posted by ITEAZR View Post
    No. Aus Hubs are smaller than the 98Spec JDM Hubs. 32mm vs 36mm diameters
    Quote Originally Posted by chech0_ed6 View Post
    No. The EK1 drive shafts will be a 32mm and the JDM 98 spec 5studs are 36mm.
    If you want it to work you will have to buy the AUDM ITR Hubs. And change the bearings. And the knuckles I think.
    無限 The Form is in the Function 無限
    teamGROUNDzero
    Aug 2005
    Cali, Melbourne
    DC2R / S2000
    so Aus spec 5 stud will fit JDM ITR B18C with 4x114.?
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    98 spec jdm dc2r uses a 36mm drivshaft so obviously the hub size will be 36mm
    to fit this to another honda you will need hubs, brakes, 36mm drivshafts handbrake lines specific to eg/dc2 or ek
    all ek9 models have 32mm hubs and will fit all models suitable for 5 lug conversion
    audm dc2r models are also 32mm hubs are pretty much identical to ek9 brakes
    obviously honda saved the best brake set up for its final release of the best b series motor made
    honda wouldnt of gone to this effort for nothing
  8. #8
    confusing ppl is confusing
    OP\, assuming this is what you're using:
    JDM 96 spec engine gearbox
    JDM 96 spec driveshafts (32mm)
    AUDM 5 stud brakes hubs
    then YES this combo will work
  9. #9
    Jan 2010
    Brisbane
    Integra
    Yup the only difference would be the 4x114 vs 5x.. everything else (i.e. Hubs & Driveshafts) are the same. Comparing JDM 96 spec vs AUDM
    p.s
    Just remember that AUDM itr brakes are 282mm and 96Spec jdm ITR brakes are 262mm's..
    teamGROUNDzero
  10. #10
    FWIW I've compared EK9 and DC2R 5 stud and the EK front knuckles are slightly shorter than EG/DC2, approx. 7mm shorter at the top. The casting is also different..
    i.e. if you use DC2R 5 stud on an EK you will get funky front camber issues....
  11. #11
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    thats funny ive used all combinations and i dont have any problems
    at the moment im got jdm 98 spec itr and dont have any issues what so ever
  12. #12
    won't be noticeable to the naked eye and it may not be a "problem" if your car is lowered
    but the taller ITR knuckle on an EK will give you less factory negative camber (possibly even positive camber on stock ride height)
    It's not widely known but is described here by a brake expert:
    http://honda-tech.com/showthread.php?p=36153087
    http://honda-tech.com/showthread.php?t=1582783
    http://honda-tech.com/showthread.php?t=1593608
