It depends on what car it is going in. EDIT I noticed you have a dc5. This will suit your car !
Just to teach you
That's a camber kit for a shock that is directly connected to the knuckle or control arm.
Here is a front suspension type that can use this as a camber kit http://www.saabcentral.com/~munki/te...sion_large.gif - real life examples are dc5's , Later Evo's
If this top is on a car with double wishbones then the adjustment does nothing but pitches the shock. Not camber
Here is an example http://www.automotive-illustrations....spensions.html
Note the shock sits separate from the knuckle and control arms. For this design , you need adjustable control arm/s to suit. Examples of cars are 91-2000 civics and integras
