Anyone tried fitting a sandwich plate for an oil cooler for a B16A gen 2? After trying to fit it, the fittings for the sandwich plate press up against the pipe in the pictures below:
Trying to turn the plate more anti-clock wise will result in the hoses pressing up against the knock sensor or alternator. If I point it to the right, the hoses don't fit because of the engine mount.
Anyone know of local suppliers for oil filter relocation kits? This is the only solution I can think of to install this oil cooler other than trying to return it back.
Been asked if I was missing the stock cooler plate and if it was a B20 block and it's not. It's got the B16A stamped on the block and did not come with a stock cooler plate.
To the "right" 3 o'clock
To the "left" 9 o'clock
