Results 1 to 4 of 4
Thread: 18x8 +45 rims
    18x8 +45 rims
    hi guys
    ive found some 18 rims which capture my heart, only issue is that they come in one size/offset in 18s: 18x8 with a 45mm offset.
    ive been informed that this size should fit both front and rear, but i may also need to roll guards.
    does anyone out there know if this size rim can fit the s2k without a big deal?
    or is the offset too high/low to be a perfect fit?
    thanks for any info
    cheers
    45 offset is perfect, and you should not have any problems with 18x8. You dont haveto roll the guards, although it will be a just fit
    Id use 18x8.5 rear and 18x7.5 front. Thats just me.
    are you running 8.5 on rear too?
    wat offset do u have?
    ive been told 50 or higher would be ideal with 8in rears
    you won't like it hondaboy, trust me!!!
