J's catback has only one outlet which increases performance but look odd on our FL rear bumper.. u can get a dual outlet with j's but the cost will be....
ECU tune will be ur last resort once everythingelse (I/H/E ) is done....then coilover and cosmatic things
PLM is a good header for Euro.. Jdmyard has them in stock....very good header..only problem..the test pipe too short.. u need to weld the cat onto it.. which may cos bit of trouble.
Didn't PLM have vibration issues, although as far as I know, it only affects Auto. I could be wrong, been a while since I've checked up on Headers. Weapon R seems the go though. Manifold should be the same with TSX and Euro. Tune for torque, it's the way to go for a DD. I find that even normally the K24 is lacking, much less with reduced torque. Lightened flywheel is another way to go if you want to improve response, no gain in power though, but it'll feel livelier.
5zigen also have single outlet exhaust just like J's that gives a *minor* bump on power.
Neither are worth the cost.
Also since OP is doing VTC (opening the engine). Tune is mandatory.
Rezone just quoted me 1.5k for flashpro with installs and tune, with the savings on headers compared to original plan I may just have some cash for cams! Or I could save for coilovers...
