Results 1 to 9 of 9
    Nov 2011
    NSW
    DC2 Integra
    Starts but takes too many cranks...b18c2
    Been happening for a while now
    If the car hasn't been started up for a while (e.g over night) and the car is cold, 1-2 cranks with the key it'll turn on...
    After it warms up, if i try start it up asap it'll be fine
    But after its completely warmed up and settled down 5-30 minutes, it takes 4+ cranks to get the thing started.
    What i realised is...it helps when i have the throttle down..
    I was looking towards fuel ...but injectors and fuel filter seems to be fine...I dont think their could be any leaks . The fuel pump seems fine because it primes fuel told by my fpr..
    - Starter relay was replaced..
    - I'm starting to look at dizzy ignition coil......
    Cheers
    Mar 2011
    Brisbane
    EK hatch, DC2
    throttle pressed when turnng on car cuts off feeding more fuel, seems like too much fuel in engine when turning on. does your car run rich ?
    tried cleaning your intake manifold & associated bits and pieces??
    Throttle Body, IACV etc??
    My car was doing this, was thinking it might be the crankangle sensor/dizzy. But have since pulled the motor apart to find the rings were stuffed. So my problem for starting was low compression.
    Hope its all good when I try to start it this weekend.
    Mar 2013
    Perth NoR
    S2k + CBX250
    spark plugs i think are a common cause. and iacv also.
    Nov 2011
    NSW
    DC2 Integra
    Quote Originally Posted by hoaanguyen View Post
    So my engine is being flooded .....Yes my car does...FPR setted on 45 Psi tho....weird...
    iacv cleaned, same with fitv...
    Manifold was taken off and cleaned a month ago...(skunk2)
    Spark plugs are 3km old...i checked and just usual wear.
    Quote Originally Posted by egsohc View Post
    My rings are slowly going but i'm really hoping its not the problem (burning oil)...I did a compression test and shown its was all close to 170ish...low but shouldn't cause any problems for now.. i'll have to double check now u made me concern..
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Sure your battery isn't dying and needs a few more CCA's?
    Are you letting the lines prime for sufficient time before cranking?
    Starter motor?
  8. #8
    Sep 2007
    Australia
    your mum
    happened to me a few times, but all for different reasons.
    once was a weak dying battary
    once was a wire toward ECU
    once was a starter motor
    once was engine flooded with fuel, too ric h, couldnt ignite.
    connorling, your profile and evidenced by your post tells me alot about what type of feral you are..... all class 'hay'!!!! ps. not your m8....
  9. #9
    Aug 2011
    Tasmania
    7x CRX, 1x EK
    I would check if your spark plugs are dirty even tho you replaced them not long ago
    Check spark plug leads
    Fuel filter and pump
    Check the batter to make sure fluid are at the right level
    Dizzy and starter motor
    And check for ecu error codes
    My style
