Page 1 of 3 123 LastLast
Results 1 to 12 of 28
    Mar 2008
    NSW
    Rice-box
    b16a2 error codes
    Been trying to get error codes for em1 civic. Bridged the PINS on SCS connector and turned on ignition switch to position 2. MIL just comes on and off like it usually does. No flashes. Any ideas?
    Green block gangster Array
    twin GX160's
    did you bridge the 2 pin connector that is blue in colour ?
    Mar 2008
    NSW
    Rice-box
    Yeah shoved a paper clip in there. nothing happened
    twin GX160's
    if it goes into diagnostic mode the MIL on the cluster should come on and stay on.
    where did you find the SCS, what colour is it
    Mar 2008
    NSW
    Rice-box
    Found the blue plug on front passenger side. Under the glovebox on the right. Do you think their could be a fault with ECU? ECU is ob2a.
    twin GX160's
    EM1 is OBDIIb
    I would deliberately force a fault code into the ECU, perhaps disconnect the MAP sensor while the engine is idling. The MIL should come on, then when you shot the SCS the MIL should pump out code 3 or code 5
    you can always reset the ECU after
    if you do not get the MIL come on and codes in the ECU the ECU has problems.
    Mar 2008
    NSW
    Rice-box
    ECU is off ek9. Ill give it a go. thanks
    twin GX160's
    ok, EK9 ECU is also OBDIIb
    Mar 2008
    NSW
    Rice-box
    Just wanted to add there is no MIL when I start the car. Does that mean no faults detected?
    Anyway started it without the MAP sensor and MIL just stayed on. No flashes. No detection? Is my issue something else non-detectable?
    Oct 2006
    P1.5 460F/350R
    Quote Originally Posted by leeman View Post
    youre not shorting the correct scs plug.
    twin GX160's
    are you bridging this connector
    hope your not bridging the 3 pin connector
