Get really confused of the abbreviation of 8th CIVIC in OZ
My name is david.I am from japan just immigrated in Melbourne and own a auto modification shop called AutoVogue back in Osaka Japan.many friends and customer modified their 8th civic in my shop,more than 10 FD2 and did 3 times fd1 k20A conversion.
First month back to Melbourne,new house just settled.Try to find a FD2 here instead taking public transport here(honestly the public transport is really inefficient and slow here),but failed so purchased a fn2 instead.
Yesterday I was browsing on this forum and saw someone selling a so-called FD2,when I clicked in.its just FD1 r20 2.0 Civic,try to correct the seller,but bring all laugh and tease today,said something like that.
FD1 - 1.8L (vti, vti-l)
FD2 - 2L (sport)
FD2r - 2L (type R)
FD3 - Hybrid
In our place the 114kW r18 sohc 2.0L civic use the exact same chassis as 1.8 r18 Civic,so wat we call is FD1 2.0.FA1 North american version and FA2 for Si.The FD2 type-r which fit the 225hp K20A engine,the chassis is totally different to 2.0L FD1 civic.Stronger and much more weld point.the engine mount point is bit different as well,FD1 can implant K20A engine but need work all through the whole chassis.even that it's still not as stronger as FD2 chassis.FN2 is also available in our place but with LSD stock and can also change the rear suspension type when u order from the honda dealer.So u guys call civic sport 2.0 also FD2,do u mean the OZ civic 2.0 use the FD2 chassis?make me quite confused.In japanese market,all we got for 8th civic are
FD1 1.8 (R18)
FD1 2.0 (R20)
FD2 (which means K20A type r)
FD3 hybrid(MF5 engine.also bit different on chassis due to battery fit)
Mugen RR FD2(240hp K20A)
few FA2(SI with K20Z2)
FN1
FN2 (K20Z2 same as si,sometimes Z4,different piston structure,bit better on quality)
MUGEN RR FN2(240HP K20A)
so in japan if u say FD2.it absolutely means civic type-r sedan.no one will get confused
dun no why in here people always say FN2R as we just say FN2,and call civic 2.0 fd1 as FD2,cause the FD2 chassis is totally a new product compare to FD1
just curious,if im wrong or the chassis of 2.0 civic sport in australia is same to FD2,my mistakes.cause in japan the R20 use the FD1 chassis as far as I saw
And another thing is fd1 2.0 civic use exact same engine point as 1.8 one,cause they r all sohc R series,just the midengine is different,i invent the word midengine,dun no the term in English.the chassis codes of fd type-r and normal fd are both near the left suspension mount under the panel.our workshop did many rebuilts of fd1 k20a conversions. fd2 chassis is specially designed and reinforced for fd type-r.and both r18 r20 use the fd1 chassis.for example just like Subaru impreza also 8th gen gda and gdb.as we said wrx8 or wrx8 sti.not only ej207 or ej205,gear box and brake different.the chassis is bit different as well.the gdb is reinforced as well,has more weld point.common mistake is people think they r the same,but actually they r not.but not as much as the huge difference between fd1 and fd2,the fd2 chassis which has a engraved code on every fd type-r and fd1 2.0 and 1.8 also has a one.as I said under left panel near the front suspension mount.the fd2 chassis is way better than fd1.a lot material is different as well.if u wanna do conversion.u need a lot of effort to reinforce and reweld the fd1 chassis.dun no why the VIN of civic 2.0 use a fd2 initial here,but as far as I know and 3 rebuilt 2.0 civic I saw before.the chassis are definitely fd1. the hybrid one chassis is redesign and modify a bit as well due to mf5 engine and extra battery,haven't see any rebuilt one but in Osaka we call it fd3 as well.
Ps:Get more and more confused since I talked about car in mel especially on sort of car like R35 and 22B and etc.makes me crazy and wanna chop my dick off
Here we only have 3 versions of the car
FD1 - R18
FD2 - K20
FD3 - hybrid
Fd2-k20?never found one here,I think u mean fd1 r20 114kw,that's the most thing I got confused,cause according to someone,it called fd2 here.so weird to me and they teased me as well.cause in japan,if u say fd2.it just means 8th civic k20a sedan type-r
lmaoooo ... more laughs to be had.
FD1 - R18
FD2 - K20
FD3 - hybrid
This may help with your confusion davidjordan -
BTW welcome mate
In Australia AUDM civic 8th gen sedans come in 3 varieties
FD1 - R18a
FD2 - K20z
FD3 - hybrid
There are no R20 engine's in Aus. They were sold through europe and asia but not AUS.
The FD2r is K20a.
Hope this helps
BTW welcome mate
FD1 - R18a
FD2 - K20z
FD3 - hybrid
The FD2r is K20a.
Hope this helps
Thx,mate.Really appreciate,now it makes sense to me why you guys classify FD2 into FD2 and FD2R,In japan if u say FD2,it just means 8th type-r sedan.
So does it mean the CIVIC 8th 2.0 use the FD2 chassis here?In that case,you guys are really lucky,cause FD2 chassis is really strong and tight compare to FD1.
In japan CIVIC 2.0 8th uses the FD1 sloppy chassis and R20 engine.
One more question,what type of K20Z using on the CIVIC 8th 2.0 here and how many BHP on it?I notice the FN2 here using K20Z2,but in Japan FN2 mostly K20Z4,better and strict emission control I think.
Hi David,
Unfortunately, the FD1 and FD2 chassis is pretty much the same in Australia besides slightly stiffer suspension and the K20Z2 instead of the R18, producing 114kw. The FN2 comes with a K20Z4 in Australia. The FD2 Type R is simply called an FD2R unofficially on the forums to distinguish it quickly and easily from the standard FD2. Unfortunately, the FD2R was never available officially in Australia. There are a small number of personal imports but they are fairly rare and pricey.
I hope that helps, and please don't get upset with some of the jokes on here. The humor and casual nature of this forum is what makes it great!
Yeah dude we are all just trolls.
How many personal import FD2R are there in OZ ? Mine and how many more
Originally Posted by davidjordan
Let me go onto Google and fetch some images of an imaginary workshop as well.
Benefit of the doubt but yes not looking legit with whiteboy username from a Japanese workshop.
But keep on topic guys. ^^
