Page 1 of 4 1234 LastLast
Results 1 to 12 of 39
Hybrid View
    Jun 2013
    Accord Euro CL9
    Unhappy EP3 engine whining noise! please HELP
    Hi everyone,
    Im new to this forum.
    My EP3 makes this whining noise when accelerating, very obvious from 2k rpm up til VTEC noise takes over.
    it is very annoying when cruising on highway.
    The drive belt seems old but spray belt dressing does not make ANY difference to the noise. The tranny fluid has also just been changed with honda MTF06, which made no difference either.
    what could be the cause?
    Heres youtube video.
    http://www.youtube.com/watch?v=CpBmM...ature=youtu.be
    Thanks a lot!
    Nov 2011
    Scooter Type R
    I think your car has this very uncommon problem that occurs in almost all cars, you know the previous owner must have installed a super charger. Not many people are that unlucky to get a supercharged ep3 :P
    Apr 2012
    Ek4_cxi_type_R
    When idling. Clutch in. Is it quiet? And how about clutch out
    MIGHT. Be the imput shaft bearing
    Not sure
    Last edited by joyride; Today at 07:26 AM. Reason: Ask for permission if you're going to use someone elses pic
    Aug 2012
    canberra
    DC2
    could be a/c compressor clutch, honestly there are several possibilities I would recommend seeing if you can identify the source of the noise and go from there.
    Oct 2006
    P1.5 460F/350R
    jsut started happening?
    try it on neutral while coasting
    Jun 2013
    Accord Euro CL9
    it is pretty quiet while idling.. the noise only gets obvious from 2k RPM
    Jun 2013
    Accord Euro CL9
    The A\C works fine too
    Jun 2013
    Accord Euro CL9
    It happens on all gears and neutral.
    Clutch does not change it either....
    Oct 2006
    P1.5 460F/350R
    Quote Originally Posted by a5sl3ss View Post
    no i mean when you drive at 80kph on freeway, then you shift to neutral
    the noise still there? or did you try revving engine while stationary?
    Jun 2013
    Accord Euro CL9
    I wil try that.. if i rev while stationary its still there
    Jun 2013
    Accord Euro CL9
    just went for a little drive, the noise goes with RPM.... doesnt matter which gear im on including neutral.
    i might try to get my drive belt replaced next week, which mechanic would have parts for this car? can anyone recommend
    Feb 2010
    EP3
    Could be an electrical fault too
