Results 1 to 3 of 3
    Feb 2005
    DC2 Integra VTIR
    Comp Cams + VTIR = ?
    Basically ive done a search, come up with 0. I was just wondering if any1 has had any expiriences with using comp cams on a b18c, any troubles were ran into ect and how much power did you see out of it and wat was the differcene in drivability. I was specifically looking at the cam part n# 57100
    Any info would be appriciated
    Cheers
    Oct 2004
    Campbelltown Sydney
    civic
    i ask weq on the forums he has a comp cam in his d-series
    Aug 2003
    Sydney, Australia
    '94 Civic VTi
    d's and b's are totally different.
    comp cams are highly regarded in the v8 world though. they now make cams for Zex so check out some of there gear and maybe u can get some info. Its a stage1 cam though, so its good for the stock ecu/valvetrain. If u go stage2+ u are looking at new springs and retainers along with an ecu retune/revlimit readjust to get the most out of the cams.
    [TNT] Team No Traction - Cos No Traction Is Underrated
    Two turbos, is better then one.
