Results 1 to 5 of 5
Hybrid View
    Sep 2012
    Nowra, NSW
    1987 CRX ED9
    97 EK1 Loose passenger Seat Rail.
    I sold my DC5R and got myself a 97 EK1. I know I know, just a bit of a downgrade but sacrifices had to be made.
    My problem is that the rail (closest to the passenger door) is rocking the chair in the back left corner. Its not a loose bolt into the floor but something in the rail itself. ANy ideas?
    I will post up pics of my little black beast later in the week. Needs some work but is a great project for me
    Remove seat, turn upside down, check bolts holding rails to seat, also check if rails or seat mountings have torn away where the bolts are, or screw into. Not uncommon. You will have to slide the rails back and forth to access the ones holding the rails to the seats.
    Jan 2010
    Cabramatta
    Canon 5d
    Dorikin had a good diy on how to fix rocking rails
    you're probably asleep right now but I love you and you're the most beautiful girl I met, inside and out. have a good nights sleep and I hope this puts a smile on your face when you wake up.
    Sep 2012
    Nowra, NSW
    1987 CRX ED9
    Its the part that slides that I think I loose but I will try that tomorrow. Too cold outside now, lol.
    Jul 2013
    Civic 99 CXi
    Sounds like missing balls in the tracks, and bet it was similar to my experience; previous owner finds steel balls rolling around floor and goes "what are these?" and chucks them out.
    Google led me to the above mentioned guide (http://www.ozhonda.com/forum/showthr...ails-(EG-EK-DC)) and was spot on when i had the same issue. If you're lucky it's just the balls missing and not the spring roller guides. I'm a newb and found it dead easy to do, now my seat is good as a new thanks to Dorikin's guide.
    ps. the dimples that hold them in aren't very big, so don't hit the rails back too hard after you fix it to save it from happening again.
