Hey People,
Recently purchased and installed Buddy Club N+ Coilover on my euro cl9.
Just need some clarifications:
1. Does everybody cars - passenger side sits higher than the driver side?
- Front Passenger is 11mm-16mm (1 finger gap and a half) higher than the Front Driver Side?
- Rear Passenger is 9mm-1.8cm (1 finger gap approx) higher than the Rear Driver Side?
All Springs is measured accordingly to Buddy Club Spec.
- Front Spring: 20cm & Front Grove: 12cm (top lower locking disc to base locking disc)
- Rear Spring: 24cm & Rear Grove: 12cm (top lower locking disc to base locking disc)
* Do you guys preload the springs: 2mm-5mm?
2. Do you need to install the 'washers' (that is cable tied on the rear coil overs when you 1stly open the box)?
3. Im hearing a thumping noise or something loose on the rear only on low speed & during some uneven roads or bumps etc... this happened after the coil over installation. any ideas?
Thanks heaps for your help
*btw which place is good for wheel alignment (incl. ingalls camber kit) also how much roughly do they charge?
