Results 1 to 9 of 9
    Feb 2011
    92 B18 eg Civic
    Standard dc2r front wheel stud length
    Hi guys, looking at buying some extended wheel studs for the front of my dc2r, the set I've found are arp and 2.85". But I have no idea on the length of the standard studs to compare with. Anybody know the specs? I only want to go about 10mm longer than standard
    Mar 2013
    Perth NoR
    S2k + CBX250
    is that measurement of the thread+spline?
    Feb 2011
    92 B18 eg Civic
    I think it's total length, but I have no idea
    Mar 2013
    Perth NoR
    S2k + CBX250
    well take your wheel off and measure the length from the tip of the thread to the rear of the plate.
    ie:
    but unless you know how that one is measured wont be much help i dont think.
    Jun 2006
    K20 DC2R
    arp wheel studs are much longer, for eg. im running them with project kiks wheel nuts and they poke out the ends. are you trying to fit spacers or something?
    Apr 2009
    rolling shell
    Most of the aftermarket extended studs are all roughly the same length billy.
    Worse comes to worse you will probably have to use open ended wheel nuts.
    Feb 2011
    92 B18 eg Civic
    Yes trying to fit spacers so my wheels will clear my calipers. What's people's thoughts on the maximum thickness spacer that can safely be run? Just a slip on, standard studs
    Quote Originally Posted by crobaa View Post
    5mm..
    Feb 2011
    92 B18 eg Civic
    Fingers crossed I won't need more than a 5mm spacer
