will 15x9 +10 fit dc2's
hey guys,
thinking of buying a set of wheels 15x9 +10
what would i have to do to fit it on a dc2 running skunk 2 shocks and spoon progressive springs.
tire size (good/safe amount of stretch), spacers, camber, guard rolling and if necessary pull out the guards abit..
just want to know exactly how to fit these wheels.
thanks in advance. tom
You'll need to stretch the tyres, maybe 195/45 or 165/45(quite a bit of stretch but this will defiantly clear your guard)
Springs ain't good for wide wheels and lowering unless its very stiff, cos when you bounce, it will smack your guards.
You'll deifnately need camber arms, rolled guards
Depends how low you're going to drop
you're probably asleep right now but I love you and you're the most beautiful girl I met, inside and out. have a good nights sleep and I hope this puts a smile on your face when you wake up.
oh okay, not too low as the cars a daily and don't want to have a hard time driving it lol
so just stretch camber and rolled guards? no spacers required?
will the width of the wheel affect anything else like not clearing etc
Then you'll need camber arms and dial in some neg camber
You won't need spacers, do you know what they are? They push your wheels out more, meaning you'll have more troubles clearing the guards
Ya.
If your wheels were 8 wide, it means the wheel is an inch smaller, hence easier to fit under the guards
But if you have wider wheels and higher offset then you could also fit them under
Width is measured by inch
Offset my mm,
Go to the integra threads, research others fiitments, and pictures and you can measure it.
Or find out the specs of your stock wheels, and measure it from there (estimate)
Work it out
Hope it makes sense ay
Regards,
Luke
oh okay,
just a stab in the dark with these wheels, thanks for the help
anyone else that can enlighten me with this stuff is more then welcome lol
kind regards, tom
im assuming these are the ccw reps ?
yep those ones
Ya.
Offset my mm,
Work it out
Regards,
Luke
thanks Luke.
15x8 +10 can be done with 175/50 or 185/50 for flush look
drop it to flush it should have natural camber of atleast -2.5...so if you do your research
it can fit with rolled and pulled guards.
invest in a camber kit.. you either go low with those specs or itll look mexican and silly.
thanks evok, just the info i was after
good info hear buddy
but yeah, he didnt want to go super low
you need to go pretty low for it to naturally camber in to fit, and hes running on springs
This is a good thread... Having had cars with ridiculous amounts of negative camber, there's a lot of other issues, tire wear, etc... If you end up with too much negative camber you'll end up with a tire that doesn't touch the road surface and mass amounts of uneven tire wear. You run into other issues with the car being front wheel drive.... I love boso cars and my Z10 Soarer... However, a DC2 Integra is really not the best candidate for a massive amount of camber.
In all honesty I could also see other problems with going any wider than an 8 on a front wheel drive car. If you want that kind of look buy yourself a Silvia, or something old school like a Laurel or a Cressi and get a set of 7s or 8s at the most for the Integra.
The notion that you'll look like a silly Mexican in a riced Honda is strong on this one. That kind of look only really suits rear wheel driven sedans and maybe occasionally something like an old school like a 240/260z... cars like my Toyota's. You're really kidding yourself if you think you can get a 9 or 10 under the guards of an Integra without mutilating it. I struggled to get a 10 under the rear guards of a rear wheel drive coupe as you can see in the first pic.
