Results 1 to 10 of 10
    Jul 2013
    EK
    Stock camber setting on a 99 ek civic hatch??
    can the front camber be adjusted on a stock 99 ek civic? if so what is the most negative camber it adjusts to? Someone told me they can be adjusted and someone said they can't.
    Apr 2012
    Ek4_cxi_type_R
    All stock upper control arms cant be adjusted.
    You will have to buy aftermarket uppercontrol arms like hardrace/buddyclub (aka camber arms) to be able to adjust the arm length. Resulting in the change of camber.
    If your exhaust is at 100mm from the ground. The fronts are usually around negative 1.5-2 degrees due to the natural camber from lowering your car on a double wishbone suspension. Which is found on ur ek.
    Last edited by joyride; Today at 07:26 AM. Reason: Ask for permission if you're going to use someone elses pic
    Jul 2013
    EK
    so I need to buy control arms to adjust the camber?
    Oct 2009
    hehe
    hehe
    Quote Originally Posted by Giuls1 View Post
    yes, or if you have adjustable coilovers you can raise/lower them to adjust it but fuk that lmao
    As pho said, just get some camber arms, and go to town.
    Jul 2013
    EK
    how much am I look at for them??
    Oct 2009
    hehe
    hehe
    brand new for my hardrace front and rear was 345 delivered. quality items, would recommend.
    Jul 2013
    EK
    alright thanks
    Jul 2013
    EK
    Can't I just get camber bolts though??
    Oct 2009
    hehe
    hehe
    not for double wishbone setup.
    Jul 2013
    EK
    I don't know now, just got new wheels and are hitting the guards when going over bumps and when the car leans.
