Hi guys, having a few problems with my b18c7. Took it to my local mechanic today and he ran an ecu scan but came up with nothing. Heres the symptoms
Sometimes a CEL will come on when I hit vtec, it will stay on until car is turned on and off, it doesnt happen often though.
Car has travelled 125km from half a tank (dc2r)
Rough lumpy idle, around 8-900 rpm and can physically feel the motor being lumpy through the pedals.
Possible fuel smell but may just be other traffic, cant be certain
Sometimes I notice a bit of a flat spot in the power band in the mid range
Its important that I mention the motor was running fine, but I replaced alot of parts as a precaution about a month ago, I cant really pinpoint what thing replaced even caused the change, if it all. May just be coincidental.
Car has brand new
Spoon Air Filter
OEM 02 Sensor
OEM Fuel Filter
New Coolant
Penrite Ten Tenths oil 10w-40/hamp oil filter
Stock JDM dc2r exhaust with 100cel cat
IAT sensor
All sensors on T/B
Iridium - BKR7EIX-11 Spark Plugs - These plugs were mentioned to me by the user on here TODA AU, although I noticed they arent listed as suitable for the car in the ngk catalouge, and the car since takes one additional crank to start, but I wouldnt say it has difficulty starting
I have also reset the ecu a few times and ran Liqui Moly injector cleaner through it and also some other brand injector cleaner (not cheapo brand)
It's also worth mentioning than on wide open throttle the car still pulls hard and feels perfect.
