Can tps cause this horrible fuel economy? The most annoying thing is my multimeter is a pro one and doesn't go down to the low voltages used by the tps. It's ironic a $10 one would do the job perfectly.
Nah got a day off tomorrow so will have a crack. Just for reference, does sca/repco sell a multimeter that scales down to those low voltages (for cheap)?
eather way the water temp sensor is under 40 buk from repco at trade price but that sort of ecconomy sounds famillia to me. once with an uncalibrated tps and once with a MAP sensor unpluged (non honda).
so both or none of the sensors mentioned could be to blame
Ok just pulled off the tps and replaced the original screws with ones I can adjust, I can't help but shake the feeling that the plug part of it was facing the opposite direction prior to taking it off. Is this the correct direction now? I lined up the stick inside in between the metal nibs.
