I may have misinterpreted your post. If you meant if it shows on the satnav screen, then it doesn't. It shows up on the radio screen as described in the link above and pic below.
D1zzo, are you familiar with the satnav service menu? From memory,
Press cancel, setup and menu together and hold for a few seconds.
service menu should appear. Select the gps option. Press and hold menu button. You should now see gps speed (in mph) and other info about satellites etc. Can do this while driving...
