at track day it pushed up to the H (backed off when it got there), no CEL or anything
Came back down again relatively quick so interested in the resolution of the factory gauge
yep on the radar to purchase, temp was ~40degrees ambient at the track so that played a large part
usually run at night so not so much of an issue but like to be able to keep an eye on things
There is no resolution. When the gauge is in its normal spot temps are between 80-95ish degrees and when it goes above that your temp is over 100 is about all it tells you
DA9 LS w/JDM SiR B18C turbo
Looking for older Honda project car pre-1985
