Originally Posted by dougie_504 Bays are normally hot, especially if you're not running a heat shield over your header. Just clean your IACV, check your FITV, check your spark plugs individually and make sure there's no water/liquid in your plug holes etc. Thanks for the reply. The problem has already been solved. It was the FITV.
