I heard that an EK doesn't have any toe adjustments for a REAR wheel alignment. Is this true? Factory doesn't come with camber adjustments in the rear aswell.
Ok just to correct you -
There is rear TOE adjustment - it is adjusted via the front of the trailing arm on a small compensator arm. Its a 14mm bolt with a washer that is loosened ,adjusted then tightened as needed. I would think all modern cars have rear toe adjustment.
Camber , is generally not adjustable on the rear,standard.And in this case its the same.
Building on what the others have said, Depending on what you're after (more or less camber for example) you can get aftermarket suspension arms to add or take a few more degrees out.
(there are also other small tips and tricks such as washers, new bushes or new springs/shocks.
