So basically my car clock resets back to 1pm when I turn off my car, anyone know what's causing my clock to reset every time my car is switched off?
My guess is that it isn't being grounded properly.
WINTON PB - 1:48.9 EG5 1.6L SOHC
has it been touched or modified before? probably someone touched the wiring for some reason and hooked it up to ign 12v instead of a constant.
S P A M | W O R K S With our special rotational tires, it will allow you to drive very fast. - JK Tyre
Check the 'back up' fuse located in the engine bay fuse box and replace - i had the same problem in my EG. This has also fixed the problem reported on other forums: http://honda-tech.com/showthread.php?t=906576
EG
Yeeahp, Blew the 7.5 AMP fuse as stated above, mine did this a couple of days ago cause I shorted a circuit whilst wiring a cluster. WHOOPS.
Replaced the back up fuse and it works fine now! cheers guys
