Page 1 of 3 123 LastLast
Results 1 to 12 of 31
    Gearbox stuffed - 04 Accord V6
    Just informed that the gearbox is dead in our 04 Accord V6 auto. $7000 to get a replacement - the car's probably not worth much more than that. Otherwise the car is in good nick, just on 200k but I don't want to spend that much money on it so might be off to the wreckers.
    Is there much call for parts for these cars? I once stripped down a Hilux Surf and sold piece by piece on ebay - did pretty well but it was a grey import so parts are hard to get and so reasonable demand. Not sure there are enough of these Honda's on the road to make it worthwhile. I don't expect to get much from the wrecker.
    Any thoughts?
    Ozhonda Trader Array
    Dec 2012
    Adelaide
    Shop around a little more for another transmission? Is it not repairable?
    Specialised Gearbox and Differential Repairs and Upgrades
    Genuine Honda Parts
    PPG, MTEC, DIMPLE
    neatgearboxes.com.au
    facebook.com/neatgearboxes
    Quote Originally Posted by chez00 View Post
    Got a quote elsewhere for $3.5 - 4.5 to repair so will probably go with that. Said he's done a few of these - common problem so be warned if your Honda is getting on in k's.
    Mar 2011
    In the middle of no where
    BA7
    shop around you can find auto box for couple hundred and another couple hundred to put it back in not 3-4k
    Quote Originally Posted by Sean628 View Post
    It won't be a couple hundred to find or to fit- but it will be less than $3-4k. I'd realistically estimate around $1500-2000 all up fitted.
    Ofcourse - being second hand you then run the risk of this happening again! But I'd choose this route and sell the car after
    Dec 2012
    Adelaide
    I reckon $4k for rebuilt installed is alright, I'd still shop a bit more though. You'll get warranty and everything too if you get it rebuilt.
    Genuine Honda Parts
    PPG, MTEC, DIMPLE
    Ok, got another quote ~$800 to put in a 2nd hand box, with no guarantee it would work. If it doesn't, another $800 to try another. Price for rebuild was higher than yesterday's quote so will probably cop the $4k and at least get a full warranty on the work.
    Jun 2012
    Perth
    CD5 & GE6
    Sure the TCU is not fried?
    How often was the g'box fluid serviced?
    www.OzAccord.net/forum
    Mar 2011
    BA7
    Yeah check the simple things first might save you time and money
    I think it is likely more than just the TCU. When it failed I had engine revs going up and speed going down. Pulled over, smoke coming from engine bay, transmission fluid dripping underneath. I don't know enough to make my own diagnosis so have to be guided by the mechanics. First diagnosis was by Honda, second will be from a transmission shop, hopefully today.
    I don't know when the A/T was last serviced - before we bought the car (at 160k). I presume it is part of the 200k service so it was probably only a few weeks away from being done anyway.
    Jun 2012
    Perth
    CD5 & GE6
    Hmmm the cause of your transmission failure
    Is the lack of fluid change and the fact the i4 and v6 share the same Auto
    Meaning the v6 torque just rips it apart
    Aug 2009
    Front yard
    4WD 89 Concerto
    You can usually get reco ones fitted for $2000-2500.
    Where abouts are you located?
    OEM parts whore
