Hi all, newbie here. I have 99 CRV Sport Auto timing belt etc replaced. Belt, pump & water coolant change $450 (Other KTAS franchise garage replaced those 40K/almost 3yr ago, but according to this mechanic they must have stuffed up. I think they did, because KTAS replaced my radiator and I had to go back 5 times for them to get it fixed properly & they also had to replace the replacement pump which was leaking only 2 month later).
Anyway, because the engine is also leaking, this mechanic had to replace
- 1 rear main seal
- 2 camshaft seal
- 1 sump gasket
- 1 crank seal
- 1 rocker cover gasket
- 4 spark o ring
Those are $600 extra. I have never owned a honda before, but is that a standard pricing for 15yr old CRV?
Cheers,
Ray
