depends some coilovers have washers for the rear lca bolt as the ek lcas are thinner then eg ones if its like that it's easy if it is for ek only u will need to shave the metal inside the lca to make it thinner. fronts are a direct fit
correct, only way ek coilover will fit EG/DC LCA is if you shave down the rear lca for fork to fit over.
