Results 1 to 6 of 6
Thread: EG Muffler size
    EG Muffler size
    does anyone have specs on the size of rear muffler that can fit in the EG's rear muffler spot?
    Looking to buy online and be good to know what other users have gotten if they have done so, or have some measurements
    I bought the Xforce one on Ebay and it fits fine. Simple 2 1/2 in and out. Was cheap too about $80- delivered.
    get something to measure the pipe diameter so you can find the inlet size
    once you have then you can check the online inlet size if it's the same or close i'm sure you can get someone to weld it if it's not bolt on
    not worried about pipe size, but more so size of the muffler iteslf.
    Munster: thanks will look at xforce stuff
    probably don't want to get anything larger that has an outlet of 4"
    should give you an idea of muffler size any larger it will look out of proportion
