If your car is old then it's probably your fuel pump strainer/filter. My 94 dc2 had similar problem, when 1/4 tank left sharp or fast turns/corners would cause the engine to turn off momentarily cause fuel feed was disrupted. I replaced it and runs perfect again.
No, track use only. Hard acceleration out of a corner to have it coff/splutter/coof & splutter some more & it's still got around 10 ltr's in the f'ing tank.
What do you other track guys do???
i replaced fuel filter.... but even with my car... i could have more than 1/4 and it still does it- only when cornering left hard. its shit as... power cuts and bogs down hard!.
i havent found a fix yet
"RIP Paul Walker. You will be sadly missed by all the car lovers out there..."
Well yes, but. If you are retaining the original fuel tank then the in tank pump will effectively be sitting in the swirl pot or tank baffling.
As the tank is about 48 litres we're going to install a non original type tank with a suitable baffle/sump/pick up, if I can find one of a suitable size!
As our races ard only short we probably only need a 30 litre tank less 10% for the foam.
Cool. Good bunch of guys. I used to race my Teg with them in 3E trim. Got to do two meetings on one weekend. Remember doing 2 qualifying and 6 races on one weekend at WP. 92 laps! All I had to do was turn the number plate sponsor panel around after each race (it was only $100 extra to double enter).
Might do the Nationals as I have a slightly 'warm' engine in the workshop that I would like to give a run.
Have you done much to your Integra? Have you 'inherited' one or built it?
Cheers
You'll know the car, it's the ex Howell (VIC) ex Payne (NSW) 2011 winning car. But, as with most of these race cars, the car that was purchased is NOT the same car that last ran in 2011. We've had to do suspension mods, gearbox ratios, brake setup's, aluminium flywheel just to get near his 2011 times and he was on A048"s and we're on A050's!!!! Plus numerous other minor annoyances that we've fixed. Now it looks like we'll need to pull the engine after last weekends SMP round as it's using about 2 or 3 litres of oil per weekend which effects the Vtec...
Still, having said that and spent quite a few thousand, are we disappointed in our 1st Honda? No way.....
That's it No.39, It's my nephews car and I'm guiding him and setting up the car as this was his 2nd raceever in the car....
You've probably seen my previous car which I just sold in Feb, now looking at a IPRA Honda to build....
