Results 1 to 12 of 14
Hybrid View
    Nov 2011
    sydney
    del sol
    Thumbs up B series headers
    Hi ozhonda people. I bought a set of PLM headers for my b series from a shop ( name held) in Sydney nearly 6mths ago. Since that time I've driven the car about 7- 10 times. The last 4 weeks i've taken the headers to the exhaust shop to get repaired. As they keep cracking around the pipe & flange. I'm over spending $100 bucks almost every 2 weeks to get these things fixed. The exhaust shop said they can make a set of mild steel headers for $900 - $ 1100 same design as i've got now which are PLM headers 4-1. Just wondering if any of you guys on this forum have bought this product & has had the same happen. The exhaust shop said its becoz they are stainless steel. And stainless steel is very weak material to make a exhaust headers. Hope some one can help me as im confused about what to do.
    YES IT FAST NO YOU CANT RIDE IT
    Take it back to the "shop" you bought it from and demand to be compensated. Easy.
    I'm guessing they are breaking along the welds at the head port area?
    Probably the material , but also quality of product and also the extra weight and force pivoting on the port welds under acceleration
    Then get rid of them and get pretty much anything else.
    Nov 2011
    sydney
    del sol
    i
    I bought them from JDM Yard. I took them back twice & the 2nd time I almost threw them at Yonas. He said that it was because there was a small scrape on the down pipe, which caused the pipe to crack away from the flange. The exhaust guy is that he is full of shit, it is because the stainless steel is shit to thin. Im never buying parts from JDM Yard ever again.
    It sucks to say but it's your word vs theirs - I send people to them all the time and it's not good to hear this- can I suggest to cut losses and repair the header sell it and forget about all of this. IMO the PLM is not a good design for this very reason
    Oct 2006
    P1.5 460F/350R
    dont blame jdmyard. plm is shit.
    you bought shit.
    Nov 2011
    sydney
    del sol
    you bought shit.
    yes I know now.
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    you bought shit.
    Stndrd stocks high quality PLM products.
    SSpamily
    ive had no problems at all with my plm 4-2-1 toda rep headers that i brought secondhand. i tigged a 6" flexi pipe and a cat straight onto the collector. do you have the brace that bolts to the back of the block attached? i had to modify the bracket on the headers because they are made for a b18 on a b16... yadedaa. what about a flex pipe? if you are missing eather the brace or a flex joint, then theres your problem. where exactly is it breaking ? at the head? or at the collector/ cat end? the oem manifold has two braces, one on the front of the block and one behind, both limit movement. stainless is a hard brittle material, but that dosent mean that allmost "all" the headers available for hondas arnt made of it....
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    stainless is not weak. Its stronger than steel, but its more expensive, so alot of manufacturers cut costs by using less material, thus the product is weaker.
    Also stainless is brittle, whereas steel has some give.
    Cheap stainless steel headers nearly always crack.
    Evo IX - THE FINAL EVOLUTION
    Nov 2011
    sydney
    del sol
    Quote Originally Posted by Limbo View Post
    yes just like mine are. I call JDM Yard 2day and had a little talk with them. Very help today. They said I could try the PLM TA headers 4-2-1 or the PLM power driven headers as well. What you guys think of these ? I used to run DC sport 4-2-1 headers, they were on the car for almost 12 years trouble free.
    Oct 2004
    Jazz EVO IX
    not sure, have a look at the headers and the welds, you should be able to see the quality, pick one that looks like a quality item. I haven't looked at B series headers for a while now so can't say
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    I'm running the PLM header no problems
    6 Months or so but I think they were on the car for some time before I purchased car
    Bad installs kill headers more than quality
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
