Results 1 to 12 of 12
Hybrid View
    Jan 2004
    Adelaide Hills
    DA9T+Euro
    Clutch recommendation
    Looking for suggestions/experience/recommendations on what clutch I should go for-
    Turbo B18C making about 170kwatw, soon to be probably about 180 and at the most to around 200 in the short to mid term. I'll be running a cable actuated box in a DA9 but with the larger input shaft and internals from a Type R.
    Concern is that if I go too heavy a clutch I'll be stretching clutch cables but too light won't handle the power.
    I was thinking this one from Xtreme- DSBMS Clutch Kit KHN22005-1R or would just a HD cover and sprung ceramic button plate suffice? (DSBHD Clutch Kit KHN22005-1B) what would be the Excedy equivalents or any other brands I should look at?
    Bit more info here if needed- http://www.ozhonda.com/forum/showthr...-LSD-questions
    DA9 LS w/JDM SiR B18C turbo
    Looking for older Honda project car pre-1985
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    I used a 3 puck exedy, the sports organic only lasted 12kkm.
    Ran great. I'd stay away from cheaply brands as they tend to have issues with higher power
    I made 173kwatw
    Evo IX - THE FINAL EVOLUTION
    Nov 2007
    Sydney
    EP3R>AH>EK>DC2
    Dean used a competition clutch on his yellow turbo Integra (it was great) and I've used one N/A applications they've held up very well.
    You bring up an excellent point on cable though - I'd like someone to chime in on that.
    SPAMMAPS
    Carburettor|Nation
    Jun 2005
    syd
    560hp
    i have also used competition clutches on my boosted b18c
    the stage 3 i used up to 250kw atw,
    then went to a bigger setup now using a stage 4 6 puck ceramic, for 340kw atw no issues.
    still streetable too.
    i would go compeition clutch again.
    so for you, definately stage 3, that's the same as Dean used as well.
    Oct 2004
    Jazz EVO IX
    With the competition Clutches i've stayed away.
    Alot of the Evo boys have had very bad quality control of the CC clutches and quite a few have failed.
    Not sure about them for hondas.
    Jun 2005
    syd
    560hp
    ive been using competition clutches for 5 years approx now.
    no issues.
    so not sure about evo ones.
    Oct 2004
    Jazz EVO IX
    on the evos the springs on the clutch plate tend to break
  8. #8
    Jan 2004
    Adelaide Hills
    DA9T+Euro
    Cheers all. So no one has experience with Xtreme? Some of the nissan guys here in SA seen to hold them in quite high regard.
    I'm thinking the stage 3 comp clutch or 3 puck excedy are approximately equivalent? And about equal to the Xtreme 1R clutch I posted?
  9. #9
    Ozhonda Trader Array
    Dec 2012
    Adelaide
    Dunno about pedal weight but the 3 puck exedy's eat gearboxes - massive shock loading. Isn't there a sprung twin organic or something? If it weren't for the pressure plate you'd be better off with your ORC.
    Specialised Gearbox and Differential Repairs and Upgrades
    Genuine Honda Parts
    PPG, MTEC, DIMPLE
    neatgearboxes.com.au
    facebook.com/neatgearboxes
  10. #10
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    After a few hard Clutches I'll always go sports organic and replace more often if required
    I had Xtreme on my boosted D16Y1 setup but i don't remember much about it...
    Never seemed like a problem and sold it after my motor blew lol
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    13.28@106.6mph 2.117 60ft On RE001
  11. #11
    Dec 2005
    Point Cook, VIC
    EK1 CXI
    Competition all the way..
    But i did use a noisy single plate ORC in my 240kw itr and was perfect...
    Pm blulude98 about xtreme... His had experience
  12. #12
    Aug 2003
    Sydney.
    EGK24A
    We are using Competition Clutch Twin Plate on our DC5 Time Attack car.
    Never had any problem with B and K series Stage 1 ( stock replacement ) / Stage 2 and Stage 4.
    JDMyard Pty Ltd
    25 / 317-321 Woodpark Rd , Smithfield , NSW 2164. Contact : 02 97572364
    Email : yonas@jdmyard.com , Facebook : http://www.facebook.com/JDMYard
    www.JDMyard.com
