Results 1 to 7 of 7
    Play in ek suspension
    Hi guys just wanting 2 find out what I should replace as I have a lot of play in
    The suspension of my ek1 sedan it has king spring coils in it but it scrapes
    On the smallest things so just wanting 2 no if I should get coilovers or replace
    The bushers 2 stiffen up the suspension
    Oct 2004
    www.alibaba.com
    porsche boxster
    what do you mean by play? as in the spring is loose or the suspension feel too soft?
    if you have the original honda springs put them back in so no more scrapes
    also the shocks probably stuffed now from using the lowered king springs.. so need new shocks I would guess
    It is like the shocks as stuffed as when I drive it scrapes
    And as I get of my drive way is scrapes every corner of the
    car but in saying that the car is not that low .....
    But in side the gards you can see how much flex it gets and I no it should
    Not scrape as much as it dose
    So I'm guessing start with coils and go from there
    It's probably the shocks.
    By scrapes do you mean the wheels scrape or the bottom of the car scrapes on the road?
    Tyres rub
    Jan 2005
    Toronto, Ontario
    Corolla Spec S
    what size wheels/tyres are you running?
    peteju captures, like us on facebook..
    Stock 15" with 195/55r
