How to install V3 Triton Rear blinkers for FK/FN
What you will need
VLED V3 Triton Amber LED system
Small hands
A Phillips Screw driver.
A torch
Adhesive Thermal tape
If you want to add the triton rear blinkers you will need the following.
The V3 Trion system.
The Base you will need is 7440/7443
1: Start by removing the control box and installing the base connector(note: if the model does not work, rotate the base connector 180°)
2: Remove the screw cover and then remove the screws for the rear housing.
3: Insert the LED module into the connector.
4: Install screws to match the tabs on the connector
5: Install the thin narrow gasket.
6: Add some thermal transfer tape to the control box and add a fuse to the load resistor fuse holder.
7: Clean the metal behind the bumper with some IPA and stick down the control box.
Before
After:
