Results 1 to 5 of 5
Thread: Eg kswap
    Eg kswap
    Any body in adelaide done a kswap?
    Putting the engine In is easy the challengeI am going to have Iis my eg was carby.
    Should I run the integra in tank fuel pump or aftermarket like walbro.
    If I run the integra one will I need the aftermarket fuel rail?
    Gonna run the dc5 radiator good idea?
    Kswap header from hybrid racing or know tuned?
    Sep 2008
    Kermit K20A
    You are best off using a Walbro fuel pump with aftermarket fuel rail, along with a return style fuel system set up.
    Also recommend using a dedicated K swap radiator, as the bottom hose is a nightmare to work out with a DC5 radiator
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
    What about the header?
    Has anyone got an eg with k20a?
    What does it go like?
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    Quote Originally Posted by repairsolutions View Post
    K swap header needed
    JDMyard Pty Ltd
    www.JDMyard.com
    Quote Originally Posted by stndrd View Post
    Really?? All I used was a stock DC5 radiator in both my DC2R and EK (Had to weld lower mounts onto EK) K-swaps with the OEM DC5 lower hose and trimmed it a lil bit on a band saw. Quite easy I thought. Top hose was off a courier or something from memory.
