Results 1 to 6 of 6
    Oct 2012
    noble park
    B20 EK
    brake pedal feel prob
    got 4 piston wilwood caliper on the ek
    i have
    1. crv brake booster and master
    2. braided lines
    brakes takes time to react
    any ideas,,
    Oct 2012
    noble park
    B20 EK
    forgot to mention i converted the rear drums to calipers
    Change the brake proportioner to a 4 disc model such as ek4 or dc2
    Then full brake bleed again
    Oct 2012
    noble park
    B20 EK
    any links on how that prop valve looks like heard its something like 60/40 or use the wilwood ones
    Oct 2012
    noble park
    B20 EK
    how do i know that ive got the proper 40/40 prop valve
    got number on it saying F9C G
    Dec 2003
    Syd
    F20C Clubman Build
    When it does react how well does it stop ?
    Jack the whole car up on stands. Get someone to depress the pedal gently hold it there and feel the resistance of the front and rear wheels.
    This will give you an idea of the brake bias. Seeing as you have converted from drums to disc at the rears and swapped for crv brake booster and m/c the prop valve as Ben has said is likely to be the cause.
    The original ek prop valve is setup to work with the oem brake setup.
    Your setup must have been done by some other honda fan before. Find out what prop valve they are using and start from there.
    GL mate
    ______________________________________________
    F20C Clubman Build
