im pretty sure rhs fan is for rad, lhs is for ac condenser.
maybe try to let your car warm up from cold, and feel lower rad hose.
if it overheats and lower hose is still cold, then check your thermostat.
S P A M | W O R K S
The drivers side fan is for the rad , the passenger side fan is for the ac radiator.
As mooch says IF the lower hose is cold that means the thermostat is not opening to let coolant flow. It's blocked or seized , replace it with a new one and properly burp your cooling system of all air bubbles.
Also try and use HONDA pre mixed coolant. It's the best stuff. You can use any other green pre mixed coolant though.
Just checked, it seems to be the opposite. The driver side fan is for the AC (turns ob only when AC is on) and the passenger side fan never spins
